How to disable all alarms
I need to extend the cable connected to the external alarm bell.
If I enter the engineer code, can I then extend the cable without fear of the alarms being activated?
Mrala
The bell should ring as soon as the power is removed regardless of whether its on day or engineering mode
If the alarm is old, diy or fitted by a muppet, it might or it might not ??
As above you need to disable the sab, self actuating bell in the bell.
As H if its not pro gear or not installed properly then it probably won't work as it should
Thanks to all for those helpful comments. Much appreciated.
The muppet is the wiser!!
Mrala
