PeterJames Posted April 16 Share Posted April 16 8 hours ago, Foggy321 said: My email is a gmail not a business one, I set it up when I bought my cameras from them so I don't get marketing emails. If the splitters are tat I won't use them Sorry the dodgy website in your link looked as if it was the type that would use a gmail address, you should have done the same when signing up here LOL Quote Link to comment Share on other sites More sharing options...
PeterJames Posted April 16 Share Posted April 16 8 hours ago, Foggy321 said: Could you send me some links as I've Googled it and I get a loads of results Thats because Ubiquity makes lots of stuff you just need a txer/rxer that suits your needs. But if you have power at the camera end then yiu could just use a POE as others have suggested Quote Link to comment Share on other sites More sharing options...
Foggy321 Posted April 17 Author Share Posted April 17 11 hours ago, PeterJames said: Sorry the dodgy website in your link looked as if it was the type that would use a gmail address, you should have done the same when signing up here LOL I've managed a temporary fix with a cheap coupler and covered the ducting with a bigger piece, I've ordered a IP67 one which I'm hoping will fit in the bigger bit of ducting then I has going to jubilee clip either side, it's a bit of a cowboy job but hopefully it will work as the camera is now working. If it fails I was going to try using that haydon splitter from the camera working on the left of the second picture Quote Link to comment Share on other sites More sharing options...
al-yeti Posted April 17 Share Posted April 17 9 hours ago, Foggy321 said: I've managed a temporary fix with a cheap coupler and covered the ducting with a bigger piece, I've ordered a IP67 one which I'm hoping will fit in the bigger bit of ducting then I has going to jubilee clip either side, it's a bit of a cowboy job but hopefully it will work as the camera is now working. If it fails I was going to try using that haydon splitter from the camera working on the left of the second picture Outdoor duct cable in the duct ? Quote Link to comment Share on other sites More sharing options...
Foggy321 Posted April 22 Author Share Posted April 22 On 17/04/2024 at 18:19, al-yeti said: Outdoor duct cable in the duct ? Yes its CAT5PE Quote Link to comment Share on other sites More sharing options...
