PeterJames Posted April 16, 2024 Share Posted April 16, 2024 8 hours ago, Foggy321 said: My email is a gmail not a business one, I set it up when I bought my cameras from them so I don't get marketing emails. If the splitters are tat I won't use them Sorry the dodgy website in your link looked as if it was the type that would use a gmail address, you should have done the same when signing up here LOL Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46695-hay-poe-multi-poe-multiplexer/page/2/#findComment-522452 Share on other sites More sharing options...
PeterJames Posted April 16, 2024 Share Posted April 16, 2024 8 hours ago, Foggy321 said: Could you send me some links as I've Googled it and I get a loads of results Thats because Ubiquity makes lots of stuff you just need a txer/rxer that suits your needs. But if you have power at the camera end then yiu could just use a POE as others have suggested Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46695-hay-poe-multi-poe-multiplexer/page/2/#findComment-522453 Share on other sites More sharing options...
Foggy321 Posted April 17, 2024 Author Share Posted April 17, 2024 11 hours ago, PeterJames said: Sorry the dodgy website in your link looked as if it was the type that would use a gmail address, you should have done the same when signing up here LOL I've managed a temporary fix with a cheap coupler and covered the ducting with a bigger piece, I've ordered a IP67 one which I'm hoping will fit in the bigger bit of ducting then I has going to jubilee clip either side, it's a bit of a cowboy job but hopefully it will work as the camera is now working. If it fails I was going to try using that haydon splitter from the camera working on the left of the second picture Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46695-hay-poe-multi-poe-multiplexer/page/2/#findComment-522457 Share on other sites More sharing options...
al-yeti Posted April 17, 2024 Share Posted April 17, 2024 9 hours ago, Foggy321 said: I've managed a temporary fix with a cheap coupler and covered the ducting with a bigger piece, I've ordered a IP67 one which I'm hoping will fit in the bigger bit of ducting then I has going to jubilee clip either side, it's a bit of a cowboy job but hopefully it will work as the camera is now working. If it fails I was going to try using that haydon splitter from the camera working on the left of the second picture Outdoor duct cable in the duct ? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46695-hay-poe-multi-poe-multiplexer/page/2/#findComment-522460 Share on other sites More sharing options...
Foggy321 Posted April 22, 2024 Author Share Posted April 22, 2024 On 17/04/2024 at 18:19, al-yeti said: Outdoor duct cable in the duct ? Yes its CAT5PE Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46695-hay-poe-multi-poe-multiplexer/page/2/#findComment-522615 Share on other sites More sharing options...
