mebz Posted September 4, 2023 Share Posted September 4, 2023 Hi. My new phone line is voip so my visonic can't call me if it goes off. I found a gsm module on ebay, but the seller says that as my alarm is v.old, adding the module could damage the unit due to the power down. I asked an installer too and he just say "at your own risk" 1/ Is there much risk of damaging the whole setup? 2/ Is there a gizmo out there which can connect to the visonic phoneline output and turn it into gsm? Thanks Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted September 4, 2023 Share Posted September 4, 2023 1) possibly, no guarantees your going to get it to work, all the risk of having no alarm. 2) You could try an ATA, no guarantees that will work but less chance of damaging the system. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted September 4, 2023 Share Posted September 4, 2023 1 hour ago, mebz said: Hi. My new phone line is voip so my visonic can't call me if it goes off. I found a gsm module on ebay, but the seller says that as my alarm is v.old, adding the module could damage the unit due to the power down. I asked an installer too and he just say "at your own risk" 1/ Is there much risk of damaging the whole setup? 2/ Is there a gizmo out there which can connect to the visonic phoneline output and turn it into gsm? Thanks Can't you just get a new control panel? I thought the detectors were all compatible? Quote Link to comment Share on other sites More sharing options...
mebz Posted September 5, 2023 Author Share Posted September 5, 2023 Thanks for getting back to me. Sorry for noob questions...what's an ATA? As for control panel, I dont believe the detectors I have (around 10 years old) are compatible with new panels. Just can't afford a big expenditure on the alarm right now...otherwise would have looked to upgrade and avoid the current issue (no phone alerts) Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted September 5, 2023 Share Posted September 5, 2023 Analog telephone adapter Quote Link to comment Share on other sites More sharing options...
mebz Posted September 5, 2023 Author Share Posted September 5, 2023 thanks! Will have a look now Quote Link to comment Share on other sites More sharing options...
JDB Posted April 2 Share Posted April 2 Did you resolve your issue Mebz, as I have the same scenario? Quote Link to comment Share on other sites More sharing options...
