Mr
4 hours ago, sixwheeledbeast said:
It seems places that fit it deal with Risco direct, fit Risco everything and wear Risco underwear...
I know a co that loves Risco the MD would definately wear Risco budgie smugglers if they made them, he is a bit strange
5 hours ago, james.wilson said:
I wonder if some companies choose this brand as its cheaper and will generate revenue in time. Be a terrible product for those that usually offer a comprehensive main / support contract
It's not that cheap, better pay slightly more right?
2 hours ago, MrHappy said:
offered this today....
naff ain't it.
Why do these nuttas insist on taking the fire and forcing into the terminals
Is it a compliance thing?
signalling via the intruder alarm dualcom don't comply regardless on how it wired
I'd rip the controls out but its 14 wireless devices + a wireless pa(s)
If it comes with an engineer I'll retain it, other wise I put a new wired alarm in?
So basically it's load of nonsense to do it that way just put a terminals block in solder if you have to or something, stupid fire cables running through panels makes nonsense
Unless there's another good reason for it?
Fire Alarms was traditionally normally open so the cable would have be fire rated to change to the normally closed state during a fire
The issue  with shared communications is the intruder panel is not rated to the same standby time as fire controls ect...
