Hard Wired Pyronix Deltabell Not Working??
Hi,
I've just hard wired a Pyronix DeltaBell (with backlight) to a Pyronix enforcer panel, but it's not working. It was previously working fine with the same panel at another location. This time, I have not wired the tamper circuit (I removed the switch), as it's up high and the fitting surface is not particularly great. I did a reset on the panel, so the Z33 for the tamper is not active. Endstation ouput/bell output is set to 014 / Siren Any.
I've only fitted 3 wires as follows:
STB on siren to STB on the panel
Bell on the siren to Bell on the panel
12V+ on the siren to +12v on the panel
When the alarm is triggered, the internal siren works fine, the outside siren does not. I don't think the comfort lights are active either?
On the siren, the battery is enabled (J8 jumper is connecting pins 1+2) on INT and the sounder cable is fitted correctly.
Am I being a total n*b, what have I done wrong here?
Thanks
Rob.
4 minutes ago, garnayrob said:
Hi,
Thanks
Rob.
What about the negative ? You still need it
Minimum you need is the
Neg -ve
Pos +12v
- bell trigger
And have the bell set to SCB mode , and make sure the bell tamper is correctly removed , I think you need the switch though for bell to work
