Risco lightsys plus with pyronix deltabell
33 minutes ago, james.wilson said:
must be output problem either blown output or programmed wrong
It's  a brand  new panel will check again the programing thanks
40 minutes ago, Naeem ahmed said:
Hi thanks sorry for getting back late the bell is working now but I can't get the strobe to work when I do a test between the negative and strobe it works but it doesn't work when alarm is ringing I got it in ou2 and program it in outputs but still nojoy
  • Replies 22
  • Views 3.6k
What did you programme it as , you have a meter to see what output is doing?
Hi I programmed it again and it's all working great now thankyou for all your help
Kind regards
Naeem
