Visonic powermax complete door contact help pls
Hi I need abit of advice please I have put the front door contact on and I went into define zones and selected delay  1 and then define panel and setup the entry delay 1 and exit delay times and it works fine in away mode but I don't want it to work in home mode at night please can help me please I have tryed lots of setting s but nojoy
Kind regards
Naeem
Kind regards
Naeem
So home mode , you don't want to arm the front door only other sensors get armed?
Yes that's correct  any  idears please would be greatfull
Kind regards
Naeem
Hi yes that's correct any idears please
Kind regards
Naeem
On 22/04/2023 at 18:20, Naeem ahmed said:
Hi yes that's correct any idears I have been through the manual but still no joy
To be honest I can't see how you will do it
Basic panel with no area settings???
Home mode and delay1 ,2 etc seem to only have certain options
What are you arming on home mode ?
Hi thanks for getting back to me if I buy the powermax 30 will that have area setting so I can omit the ones I don't want to arm at night
34 minutes ago, sixwheeledbeast said:
There is no such thing as a Powermax 30.
Hi thanks for getting back to me I take it the powermax complete does not have a part set options
Sorry powermaster 30
