james.wilson Posted August 11, 2022 Share Posted August 11, 2022 but when you wire it like it sounds all the time? WHat does your meter read between bell and HO+ 2 Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
Imnotshankled Posted August 11, 2022 Share Posted August 11, 2022 6 hours ago, james.wilson said: but when you wire it like it sounds all the time? WHat does your meter read between bell and HO+ I have one of these the connections are + - and 2 tamper terminals + should go to 12 on panel - should go to bell (output 1003) on panel T should go to the t on panel T should go to 0v Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted August 11, 2022 Share Posted August 11, 2022 If you read the question it sounds when wired like this, so it's a programming issue... Likely something inverted or programmed wrong. Quote Link to comment Share on other sites More sharing options...
Imnotshankled Posted August 11, 2022 Share Posted August 11, 2022 3 hours ago, sixwheeledbeast said: If you read the question it sounds when wired like this, so it's a programming issue... Likely something inverted or programmed wrong. Read OPs message again The issue they are having is they don't know where to put the siren -ve on the panel they have been putting it in the 0v hold off connection and its been causing the alarm to go off If it is a programming issue go to engineer mode, select option 53 type in 03 and make sure it is set to bell and the state is positive On 09/08/2022 at 16:14, MichaelZoolingen said: but when i put blue cable in - then it will go off, Quote Link to comment Share on other sites More sharing options...
james.wilson Posted August 11, 2022 Share Posted August 11, 2022 Sorry I assumed from the op he was connecting it to bell - 1 Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
Imnotshankled Posted August 12, 2022 Share Posted August 12, 2022 10 hours ago, james.wilson said: Sorry I assumed from the op he was connecting it to bell - I guess you can teach a old dog new tricks Quote Link to comment Share on other sites More sharing options...
MichaelZoolingen Posted August 12, 2022 Author Share Posted August 12, 2022 20 hours ago, Imnotshankled said: Read OPs message again The issue they are having is they don't know where to put the siren -ve on the panel they have been putting it in the 0v hold off connection and its been causing the alarm to go off If it is a programming issue go to engineer mode, select option 53 type in 03 and make sure it is set to bell and the state is positive Yes thanks i have set siren on 1002, and now working good. 1 Quote Link to comment Share on other sites More sharing options...
