Enabling Sounder for Tamper Event
A quick question. I opened my control panel (HKC SW10 70) and noticed I just get a repeated beep. Without trawling through the installation manual, can anyone tell me the menu option for to enable the internal sounder for tamper events? Also, is activation of the sounder per each tamper on zone, or does it have to be either on/off globally for all tampers?
Edited by Eugene's DIY Den
  • Eugene's DIY Den changed the title to Enabling Sounder for Tamper Event
WHat do you have the internal siren programmed a, if its bell it wont when unset
I remember I had an issue before when it wasn't activating on bell, or there was a delay when it activated after the external sounder operated, so I must have changed those settings. Now I have to try and remember how I did this.
What is your internal sounder programmed as?
I don't know. How do I check?
There's no option to change it in the Devices menu. I presume the option to change it is buried in one of the other menus?
Think it says output panel 1234 of something like that
Would be nice if the hkc used galaxy style menu numbering , so much easier lol
