Texecom Premier Elite vs Hikvision AX Pro
23 minutes ago, MrHappy said:
if you have a job for all the radio tat....
a P48-Live is "free" panel for a little wired system in an outbuilding ?
Thank you - you’re right but the customer says the shed is quite a long way from the house and anyways, they want to know if the alarm is sounding wherever they are… I can’t help thinking maybe your two system suggestion could be easiest but there would be some saving by creating two areas.
1 minute ago, sixwheeledbeast said:
64W-LIVE is the replacement, can get in kit form and break up.
Thanks… the issue is needing remote control (via app) to alert the user if the alarm is sounding.
Thanks also for pointing out the keypads have zones… difficulty is it’s only two, hence thinking about the expander.
So overall not much worth protecting in there anyway? I suppose texe app system is still free?
