June 17, 20214 yr comment_511277 A dodgy or misconfigured anything on the network "could" cause it. Have to try and isolate to narrow it down somehow. You should be able to calculate what bandwidth should be on each link if you add up all the equipment. I guess these are unmanaged switches so you can't look at logs or change any QoS/Bandwidth settings etc. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44623-ip-drop-out/page/2/#findComment-511277 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 17, 20214 yr Author comment_511278 9 minutes ago, sixwheeledbeast said: A dodgy or misconfigured anything on the network "could" cause it. Have to try and isolate to narrow it down somehow. You should be able to calculate what bandwidth should be on each link if you add up all the equipment. I guess these are unmanaged switches so you can't look at logs or change any QoS/Bandwidth settings etc. Correct all unmanaged But I get what your all saying , thanks for the guidance will look into it Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44623-ip-drop-out/page/2/#findComment-511278 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
