June 8, 20215 yr comment_511181 Hi I installed a optima G4 in place of existing faulty alarm. As it was only a basic system I upgraded the system by installing additional PIRs. The PIrs are honeywell Activ8 and have a internal built in resistance on the alarm contacts of 17 ohms giving approx 20 Ohms on the loop. Also I installed 2 PIrs in series for zone 2 to allow entry/exit inhibit for front door and side door, this doubling the loop to 39 Ohms. The manual does not mention zone resistance and the diagrams just show N/C contacts. Is there a max resistance on the input zones? Door entry and window contacts are just a few ohms wire resistance. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44611-optima-g4/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 8, 20215 yr comment_511186 Wouldn't recommend pirs in series, after a fa how do you know which one went off ? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44611-optima-g4/#findComment-511186 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 8, 20215 yr comment_511187 agreed. It will work like driving with no windscreen but its not best. If you need more circuits use a bigger panel securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44611-optima-g4/#findComment-511187 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 9, 20215 yr comment_511191 There will be a resistance threshold for closed loops but the lower the better, usually it's around 100-200 which you don't want to be near, but will vary on panel. Issue is diagnosing future issues when you have multiple devices on a circuit, as above. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44611-optima-g4/#findComment-511191 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 10, 20215 yr Author comment_511195 Thanks for the replies, i know it was not ideal using 2x pirs in series. But I can free up a zone (Window contacts) and connect PIR in that room in series with the window contact, therefore ie zone 4 PIR+ window contact . That would allow the entry/exit zones to have their individual PIR (Timed). I was more concerned about the loop resistance. All loops then would be in the 20-22 Ohm range, except for door entry Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44611-optima-g4/#findComment-511195 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 10, 20215 yr comment_511196 If there aren't enough zones it needs a bigger panel. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44611-optima-g4/#findComment-511196 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
