flexdiy Posted January 26, 2021 Share Posted January 26, 2021 Hi, So I've successfully paired this keyfob so that I can set and unset the alarm, however the panic alarm just sends an SOS to the ARC and I want it to sound the siren. I cannot find anything in the docs on how to do this, so if someone could advise it would be very much appreciated. thanks in advance Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44328-galaxy-flex-tcc800m-panic-alarm-how-to-set-off-siren/ Share on other sites More sharing options...
james.wilson Posted January 26, 2021 Share Posted January 26, 2021 tried this? Quote To enable the panic function on an existing keyfob: Note: Enable [51.60.2] before selecting this option. 1. Select 2=Fob PA, and then press ent. 2. Select 1=Enabled. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44328-galaxy-flex-tcc800m-panic-alarm-how-to-set-off-siren/#findComment-507895 Share on other sites More sharing options...
flexdiy Posted January 26, 2021 Author Share Posted January 26, 2021 4 minutes ago, james.wilson said: tried this? Hi James, thanks for the reply but as I say the panic function works just fine, it's just silent. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44328-galaxy-flex-tcc800m-panic-alarm-how-to-set-off-siren/#findComment-507896 Share on other sites More sharing options...
james.wilson Posted January 26, 2021 Share Posted January 26, 2021 Oh ok Dont know the flex that well. If its not programmable (others will know more) you could link a circuit to an output (circuit programmed as PA, output programmed to follow the RF keyfob) securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44328-galaxy-flex-tcc800m-panic-alarm-how-to-set-off-siren/#findComment-507901 Share on other sites More sharing options...
al-yeti Posted January 26, 2021 Share Posted January 26, 2021 1 hour ago, james.wilson said: Oh ok Dont know the flex that well. If its not programmable (others will know more) you could link a circuit to an output (circuit programmed as PA, output programmed to follow the RF keyfob) Does the galaxy have a silent pa setting? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44328-galaxy-flex-tcc800m-panic-alarm-how-to-set-off-siren/#findComment-507903 Share on other sites More sharing options...
GalaxyGuy Posted January 27, 2021 Share Posted January 27, 2021 13 hours ago, flexdiy said: Hi James, thanks for the reply but as I say the panic function works just fine, it's just silent. You need to program a link from the silent PA output to the bell output. This will not work on a trigger output, it needs to be a proper output. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44328-galaxy-flex-tcc800m-panic-alarm-how-to-set-off-siren/#findComment-507925 Share on other sites More sharing options...
