Ade Gen 4 alarm at clinic
The door chime has stopped working, checked the alarm system and it is activated, how do I check the sensors ?
There's a chime in off , maybe you switched  on off
And I assume when you set alarm, coming back in does start the entry timer?
Edited by al-yeti
Clinic alarm is set and chime noise can be activated for other sensors, for some reason door chime has stopped, system working otherwise
What happens if other sensors have no chime and you set doorn chime on and off
So the door is main door and when you open it , it starts the entry timer without you having to walk in?
40 minutes ago, seary physio said:
Reactivated it using a magnet !!! Strange but true !!
the reeds sticking,
its a tiny glass tube, age / temperature changes, door slamming the gas escapes & it sticks
eventually it will fail open or closed
replace the contact
I assume business is on its arse ?
However if you have the £'s I say replace it with a proper one ?
Replace the contact as soon as possible
