Henrik Posted October 29, 2020 Author Share Posted October 29, 2020 I will attach a short movie on what the display says and a pic on how it looked before I took the old cables away. I put the 1k resistor between 1002 and 0V to the left of 1002. On the film it says (in Swedish): 1003 +SAB.Open circuit IR store floor 1002 +SAB.Short circuit IR store office Not beging an alarm technician guy I just guess that 1001 (that's a door magnet) would have 1=white and 0V=Blue and the 1002 that's an PIR would be connected with 2=purple 0V=green and blue and then the white to 12V on pin 7. IMG_1265.MOV Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44167-how-do-i-get-this-to-work/page/5/#findComment-505795 Share on other sites More sharing options...
al-yeti Posted October 29, 2020 Share Posted October 29, 2020 9 minutes ago, Henrik said: I will attach a short movie on what the display says and a pic on how it looked before I took the old cables away. I put the 1k resistor between 1002 and 0V to the left of 1002. On the film it says (in Swedish): 1003 +SAB.Open circuit IR store floor 1002 +SAB.Short circuit IR store office Not beging an alarm technician guy I just guess that 1001 (that's a door magnet) would have 1=white and 0V=Blue and the 1002 that's an PIR would be connected with 2=purple 0V=green and blue and then the white to 12V on pin 7. IMG_1265.MOV Going to basics If your remove the wiring and put a resistor in the correct place it should clear any fault that is present there Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44167-how-do-i-get-this-to-work/page/5/#findComment-505796 Share on other sites More sharing options...
al-yeti Posted October 29, 2020 Share Posted October 29, 2020 In your picture above zone 3 shows the wiring sheath isn't removed and can be a problem , did you correct that? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44167-how-do-i-get-this-to-work/page/5/#findComment-505797 Share on other sites More sharing options...
al-yeti Posted October 29, 2020 Share Posted October 29, 2020 On 28/10/2020 at 18:10, Henrik said: Ok guys, got everything up and running just fine. i do however have an slight issue. when I took the alarm down I most have missed one PIR hanging on the wall (address 1002). how do I go about entering the engineer code to be able to delete the address 1002? And is the engineering code always the same or is it changeable by the company who first installed the system in my old shop? thanks in advance, Henrik. Another thing , show a picture of how one of your pirs is working , how is it wired and what resistors are inside it This will help you why your not able to clear the fault on z2& z3 Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44167-how-do-i-get-this-to-work/page/5/#findComment-505798 Share on other sites More sharing options...
Henrik Posted October 29, 2020 Author Share Posted October 29, 2020 2 minutes ago, al-yeti said: In your picture above zone 3 shows the wiring sheath isn't removed and can be a problem , did you correct that? the picture above is the old wiring, and the film showing the new. Where would I place the resistor then to place it in the right place. :0) Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44167-how-do-i-get-this-to-work/page/5/#findComment-505799 Share on other sites More sharing options...
Henrik Posted October 29, 2020 Author Share Posted October 29, 2020 Here is a pic how I wired PIR 1003 up. Blue= Ground, Orange= 12V Brown= alarm Green= tamper Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44167-how-do-i-get-this-to-work/page/5/#findComment-505801 Share on other sites More sharing options...
al-yeti Posted October 29, 2020 Share Posted October 29, 2020 24 minutes ago, Henrik said: Here is a pic how I wired PIR 1003 up. Blue= Ground, Orange= 12V Brown= alarm Green= tamper What values are the resistors? As you used the tamper one to put on the panel All I am saying if you can't clear the fault with a simple resistance, then your eol must be set different to what your putting in and it doesn't matter what sensor or cable your using , all of no consequence What happens if you move a sensor from further up to zone two or three , it should clear the fault and send the fault to other Rio output Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44167-how-do-i-get-this-to-work/page/5/#findComment-505803 Share on other sites More sharing options...
Henrik Posted October 29, 2020 Author Share Posted October 29, 2020 The resistors are Brown.brown.black.black.brown 110 ohms +/- 1% moved 1003 to 4 and 1004 to 3 and that cleared the problem on +SAB 1003. still got the problem on 1002 that supposed to be a PIR but still sits on the wall in my old shop. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44167-how-do-i-get-this-to-work/page/5/#findComment-505805 Share on other sites More sharing options...
al-yeti Posted October 29, 2020 Share Posted October 29, 2020 Just now, Henrik said: The resistors are Brown.brown.black.black.brown 110 ohms +/- 1% moved 1003 to 4 and 1004 to 3 and that cleared the problem on +SAB 1003. still got the problem on 1002 that supposed to be a PIR but still sits on the wall in my old shop. Can't be 110 needs to be 1k I thought Unless your saying all the zones set up that way Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44167-how-do-i-get-this-to-work/page/5/#findComment-505806 Share on other sites More sharing options...
Henrik Posted October 29, 2020 Author Share Posted October 29, 2020 Sorry mate, it’s brown black black brown brown 1k +/-1% Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44167-how-do-i-get-this-to-work/page/5/#findComment-505807 Share on other sites More sharing options...
