Risco wireless shock sensors tamper issue
Now it’s pissing memoff
Peogrammed sensors to off in main panel (program zone types) and still triggers a tamper alarm frequently
Tried taking battery out and this triggers another error code with an “L” after it when trying to set the alarm.
Any ideas please
  • Replies 20
  • Views 11k
"L" means lost,
"delete the circuit off " aka remove the transmitter in the zex menu 91-98 or whatever +no ?
8 hours ago, MrHappy said:
"L" means lost,
Hi and thanks for the reply but I am still a bit confused. I have the programming manual for the panel but can’t find the program option to remove the transmitter . You refer to the zex menu but not exactly sure what you mean .
Soory to be dim but am not super familiar with this setup
You using right access code?
You need to enter eng code then user code.... scroll to Zones....enter 50 Yes and work your to disable wireless zones etc.
Sorry there ain’t no zone 50
it’s a gardtec panel with a a separate wireless box wired in to the main panel
You menu menu 50?
23 hours ago, paulbaker1954 said:
Menu 50 is zone wiring (EOL) etc
Thanks all got it figured out now ???
