August 3, 20206 yr comment_503843 Hi, Does anyone know how the PGM output on the Visonic powermax+ is supposed to operate? I assumed originally that it was just pulled low when active, but it seems to be low all the time. You can see some info on topic here where another user was also confused by it: https://www.thesecurityinstaller.co.uk/community/topic/25353-powermax-pgm-output/ I've tried pulling it up with resistors, but it won't switch "off". Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44010-visonic-powermax-pgm-output/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 3, 20206 yr comment_503844 6 minutes ago, BaconAndCabbage said: Hi, Does anyone know how the PGM output on the Visonic powermax+ is supposed to operate? I assumed originally that it was just pulled low when active, but it seems to be low all the time. You can see some info on topic here where another user was also confused by it: https://www.thesecurityinstaller.co.uk/community/topic/25353-powermax-pgm-output/ I've tried pulling it up with resistors, but it won't switch "off". Might floating so dosent react same way Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44010-visonic-powermax-pgm-output/#findComment-503844 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 3, 20206 yr Author comment_503845 It doesn't appear to be floating, it has continuity with ground. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44010-visonic-powermax-pgm-output/#findComment-503845 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 3, 20206 yr comment_503846 9 minutes ago, BaconAndCabbage said: It doesn't appear to be floating, it has continuity with ground. Eh? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44010-visonic-powermax-pgm-output/#findComment-503846 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 3, 20206 yr Author comment_503847 It's connected to ground. I've checked with a meter and it's connected to ground. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44010-visonic-powermax-pgm-output/#findComment-503847 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 3, 20206 yr comment_503849 11 minutes ago, BaconAndCabbage said: It's connected to ground. I've checked with a meter and it's connected to ground. So it's negative remove then perhaps Or positive removed or something lol Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44010-visonic-powermax-pgm-output/#findComment-503849 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 3, 20206 yr comment_503851 There is loads of options for what it does, pulse, toggle, pressing the star on the fobs, all in the "Define Outputs" settings. It maybe set to disabled? +ve applied IIRC but will not supply much current, as they are not designed for supplying power to much. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44010-visonic-powermax-pgm-output/#findComment-503851 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 4, 20206 yr Author comment_503862 I actually just want to use it to monitor when the alarm's set via a wifi dongle I made, so I need no current really. I have it set to turn on when home or away or armed, but it never changes from being a ground. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44010-visonic-powermax-pgm-output/#findComment-503862 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 4, 20206 yr comment_503864 2 hours ago, BaconAndCabbage said: I actually just want to use it to monitor when the alarm's set via a wifi dongle I made, so I need no current really. I have it set to turn on when home or away or armed, but it never changes from being a ground. Relay? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44010-visonic-powermax-pgm-output/#findComment-503864 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 4, 20206 yr Author comment_503865 Are you telling me to put a relay across it and see what happens? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44010-visonic-powermax-pgm-output/#findComment-503865 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
