Visonic PB-102 panic button no panic alarm
Hello,
DIY install of a Visonic Powermaster 360R.
Added PB-102 2 button panic button through enrolling.  Disarm key successfully disarms, red flash/green flash.  Arm key successfully arms same red flash/green flash.
Zone type set to PANIC.
Pressing both keys for panic - double red flash and no response from alarm.
Change zone type to EMERGENCY from PANIC and red flash then green flash on double key press and alarm sends out emergency alert to Visonic-Go.  However siren does not sound so not ideal.
Panic alarm set to audible in control panel menu.
Why will it not panic ?
Thanks !
Alex
