May 23, 20206 yr comment_501663 hey guys Looking for abit of advice. My dads got a scantronic 9448 with a built in keypad. He'd like to relocate the control panel and just have a keypad. Is there any other keypads compatible with the control panel other than the 9427 keypad. He likes the KEY-KP01 but unsure if this will work. Thanks Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43839-scantronic-9448-keypads/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 23, 20206 yr Author comment_501665 1 minute ago, Logan said: The key-kp01 will only work with the ion panel You can only use the 9427 Thanks for confirming that. Dam really as the 9427 are quite ugly. Is it the same case with the pirs or will any pir work? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43839-scantronic-9448-keypads/#findComment-501665 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 23, 20206 yr Author comment_501667 2 minutes ago, Logan said: Any pirs will work If you plan to relocate the panel you can upgrade the controls to something like a scantronic ion 30 Hes only just upgraded his panel to the 9448 as hes old one went faulty and just decided to change it like for like with the newer model. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43839-scantronic-9448-keypads/#findComment-501667 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 23, 20206 yr comment_501668 Shame you could have almost certainly got a 9651 for the same money which is what it sounds like you are looking for now. So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43839-scantronic-9448-keypads/#findComment-501668 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 23, 20206 yr comment_501672 2 hours ago, slacky said: Hes only just upgraded his panel to the 9448 as hes old one went faulty and just decided to change it like for like with the newer model. Get rid of panel You mean he just replaced not upgraded Might be ugly but if he really wants a keypad then you just use what's compatible, as it's a security device just tell him don't worry about it not smiling at you .... ? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43839-scantronic-9448-keypads/#findComment-501672 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 23, 20206 yr Author comment_501690 ill let him know and see what he thinks although i know the answer already lol Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43839-scantronic-9448-keypads/#findComment-501690 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
