Honeywell Galaxy E080-04 Ethernet Module Cables?
34 minutes ago, norman said:
My carbon monoxide detector kept activating and the noise was giving me a headache so I've taken the battery out.
Lol joker buy new one
  • Replies 27
  • Views 7.3k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • My carbon monoxide detector kept activating and the noise was giving me a headache so I've taken the battery out.
  • All done guys, the virgin media super hub 3 requires you to make a rule for the MAC address and the assign the IP address. That particular page from virgin takes around 15 mins to run a script, I thou
  • Nah
2 hours ago, al-yeti said:
So what's the a083?
A083-00-01, or A083-00-02 or A083-00-10 Flex Intellibus Ethernet Module part numbers.
On 04/12/2019 at 12:20, al-yeti said:
Why won't it work?
That’s what Honeywell tech help told me. They said it had to be a A083-00-10. Ive bought a -10 now and I’m still struggling with it.
On 04/12/2019 at 16:50, GalaxyGuy said:
The E080-4 will only work on the older V1.X Flex panels. The V3 panels use the faster intellibus for comms devices and camera PIR's and it requires the A083  Ethernet module.
That’s great info, how do I know what version Flex I have? I now have both Ethernet modules and I’ve connected up the -10 one but my router doesn’t see it. I’m trying to get the app up and running in my phone. All the led’s on the module are as expected and I’m not getting any faults in the keypad.
On 04/12/2019 at 12:20, james.wilson said:
What you trying to do with it. I don't use the flex but I'd of thought it would see it an external ethernet one on the data line
Sorry for late reply, I’m trying to get the app working on my phone. Can’t even see the ip address on my laptop to ping it.
Assuming your panel sees the ethernet card???
If you set it an IP static can you ping it
I would default your router aswell
I’m sure it sees it, all the led’s are fine and I’m not getting a comms error. The router doesn’t see the MAC address either so I can’t set a static ip
why default the router?
Edited by tinnitus
You can't set an IP on the panel? And gateway or subnet?
What reason you have not to?
I don’t want to just do random things without reasonable justification, it’s an extra step that’s probably not required.
All done guys, the virgin media super hub 3 requires you to make a rule for the MAC address and the assign the IP address. That particular page from virgin takes around 15 mins to run a script, I thought it was just not responding. I walked away and came back and it was all ready to go.
Edited by tinnitus
