Christopher Taylor Posted October 25, 2019 Share Posted October 25, 2019 (edited) I've just installed a texecom 64-w panel with smartcom. SmartCom seems good, but I'd prefer to have signalling equipment installed as in my opinion it should be more reliable. I'm looking for call or text notifications to keyholders if the alarm goes off. I've considered comGSM, however before I purchase I want to see if I can use dual path signalling equipment available, for reliability. Do any ARCs sell equipment and services directly to end users? To the best of my knowledge most will not. Is there any dual path signalling equipment out there that does not need to be connected to an ARC to work? The house is located in France. French installers are quoting several hundred euros per month. Edited October 25, 2019 by Christopher Taylor Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43213-arc-monitoring-as-a-diyer/ Share on other sites More sharing options...
PeterJames Posted October 25, 2019 Share Posted October 25, 2019 You could get an installer to connect it to the ARC but I doubt vmuch you will get an ARC willing to take on a diy install, dual path monitoring in the UK starts at £350.00 per annum in the UK. You can get dual path app monitoring Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43213-arc-monitoring-as-a-diyer/#findComment-489897 Share on other sites More sharing options...
al-yeti Posted October 25, 2019 Share Posted October 25, 2019 2 hours ago, Christopher Taylor said: I've just installed a texecom 64-w panel with smartcom. SmartCom seems good, but I'd prefer to have signalling equipment installed as in my opinion it should be more reliable. I'm looking for call or text notifications to keyholders if the alarm goes off. I've considered comGSM, however before I purchase I want to see if I can use dual path signalling equipment available, for reliability. Do any ARCs sell equipment and services directly to end users? To the best of my knowledge most will not. Is there any dual path signalling equipment out there that does not need to be connected to an ARC to work? The house is located in France. French installers are quoting several hundred euros per month. You can dualpath DIY Just buy a dialler and a GSM SMS unit and stick them both on , some will even poll for you , with enough inputs you can even get the GSM unit to message on line fail Other than getting an installer and monthly contract you might as well forget about the arc Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43213-arc-monitoring-as-a-diyer/#findComment-489901 Share on other sites More sharing options...
Christopher Taylor Posted October 25, 2019 Author Share Posted October 25, 2019 1 hour ago, PeterJames said: dual path monitoring in the UK starts at £350.00 per annum in the UK. Thanks for a price - at least it puts in perspective my current quotes of around 350 EUR every 3 months! 1 hour ago, al-yeti said: Just buy a dialler and a GSM SMS PSTN Dialer? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43213-arc-monitoring-as-a-diyer/#findComment-489902 Share on other sites More sharing options...
al-yeti Posted October 25, 2019 Share Posted October 25, 2019 38 minutes ago, Christopher Taylor said: Thanks for a price - at least it puts in perspective my current quotes of around 350 EUR every 3 months! PSTN Dialer? Yes pay dialler DIY dialling It's DIY or installer with arc Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43213-arc-monitoring-as-a-diyer/#findComment-489903 Share on other sites More sharing options...
