Chappie Posted September 9, 2019 Share Posted September 9, 2019 Hi, looking for the quietest 8/16ch PoE NVR for installation in a residential living area. Any recommendations? Fanless? Solid state SSD drive? TIA. Quote Link to comment Share on other sites More sharing options...
james.wilson Posted September 9, 2019 Share Posted September 9, 2019 I wouldn't use an ssd. You could change the fans for larger units but most need some air movement Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
Chappie Posted September 9, 2019 Author Share Posted September 9, 2019 Thanks. I assume that SSD would have a shorter life but if noise limitation is paramount, might it be a price worth paying? Can you recommend an NVR which under typical light domestic load of, say 4 cameras, would be liveable with? Of course, ideally it would be removed from the living area but in this instance it is required to be close to the TV and accessible via remote control or mouse. Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted September 9, 2019 Share Posted September 9, 2019 Something is wrong if you have hard drives that make noise louder than ambient. SSD would not be recommended at all. There are 4 way DVR's out there with passive cooling never seen an NVR tho due to the PoE and anything bigger would normally have a fan. NVR/DVR fans are normally the small noisy type so you could go custom and replace the fan for a better one using the fan header. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted September 9, 2019 Share Posted September 9, 2019 2 hours ago, Chappie said: Thanks. I assume that SSD would have a shorter life but if noise limitation is paramount, might it be a price worth paying? Can you recommend an NVR which under typical light domestic load of, say 4 cameras, would be liveable with? Of course, ideally it would be removed from the living area but in this instance it is required to be close to the TV and accessible via remote control or mouse. Use non Poe NVR and put it somewhere else? Quote Link to comment Share on other sites More sharing options...
Chappie Posted September 9, 2019 Author Share Posted September 9, 2019 10 minutes ago, al-yeti said: Use non Poe NVR and put it somewhere else? Yes, I did consider that - but ongoing access to the front panel of the NVR is needed so there would be no escaping the disk chatter. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted September 9, 2019 Share Posted September 9, 2019 1 hour ago, Chappie said: Yes, I did consider that - but ongoing access to the front panel of the NVR is needed so there would be no escaping the disk chatter. Y you need access ? To front ? Quote Link to comment Share on other sites More sharing options...
james.wilson Posted September 9, 2019 Share Posted September 9, 2019 Use a nas drive then or a green one to reduce the noise Imo only hi speed drives are loud and you won't need it for 4 cams Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
Chappie Posted September 9, 2019 Author Share Posted September 9, 2019 46 minutes ago, al-yeti said: Y you need access ? To front ? For mouse or IR remote control. Quote Link to comment Share on other sites More sharing options...
james.wilson Posted September 9, 2019 Share Posted September 9, 2019 Is the client or you not fussed about theft of device in that location? Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
