Hello Everyone,
I have recently bought a house and I have already  PowerMaster10 ADT security alarm installed but I have no installer (or master installer?) codes for it to change code for arming and disarming alarm. I tried reset it according to instruction found on the internet but it didn't work. Any chance to reuse it or it is junk now?
Edited by sixwheeledbeast
update topic title
If it's ex-ADT I would assume junk status simply due to the fact the codes are probably locked.
Whether you can get a new main unit and re-sure the sensors though, would be for someone else to answer?
Standard panel defaults to 8 minutes bell time but no idea with ADT model it's likely got different default settings with it's custom firmware. Detection devices and bell times would be installer programming only.
People rarely go to that much trouble, they will just kick a door in and be back out in <3 minutes.
If you are concerned get a professional in to advise and sort it.
19 minutes ago, JohnJohnJohn said:
So anyway it is a bit dangerous leaving possible access to my home security system... How can I be sure that somebody who can (have) access to my security alarm not gonna disarm it while I'm away? It not safe, is it?
Simple don't connect it to the internet or apps in the first place.
Register a new account
Sign in
