Galaxy Flex FX020 Factory Reset
54 minutes ago, norman said:
Regardless, if it's not as described eBay have a great returns policy. Nothing to lose imo.
You known da score man
Just buyit
  • Replies 26
  • Views 15.1k
  • Specialist
    Specialist
    The thing is, you might be totally legit in your request but we don't actually know that or have any way to verify it. Also if we were to give this information out then anyone could access it, Obvious
  • Regardless, if it's not as described eBay have a great returns policy. Nothing to lose imo.
  • GalaxyGuy
    GalaxyGuy
    Depends if it fails after a week or two. Pain in the butt if you need to swap out the controls to return.
'yetiz_hot_dealz_2019', where every system comes with a slightly rattly sounding 1.2Ah Hongfeng lead-substitiute genuine-acid backup battery.
Just get back to work with the scanny enquiries, I been blagging it since you disappeared
20 hours ago, Specialist said:
Hi: You could try dropping a pm to Peter James, he's up your way somewhere. He may be able to help or suggest someone that can.
Did you actually change the Engineer code from the factory default code at time of installation ? A lot of DIY installers don't.
I must have change it as I have tried the default ###REMOVED### and no work. Ive tried all may usual PIN's but eventually it locks the panel out for 5 min. I have a plan to wire all the 3 sensors in the garage in series and connect to the sensor input for the landing for now.
Edited by sixwheeledbeast
No codes in posts please
Yeah I read the court transcripts
