SL Compact motion sensor change
Hi all.
Converted my garage into a man den.
My alarm is an SL Compact.
Anyway had a PIR in there and decided to change it to a new shiny one to go with the new paint work. The older PIR had gone yellow.
Disconnected old PIR reconnected new one and now alarm panel has Zones 2,3 & 4 lit up. These are PIR Zones. I think Zone 1 is the front door & Zone 5 the back door.
I cant set alarm now.
Btw way, (stupidly) I dint turn the power off to the alarm whilst doing the change.
My question; Could I have damaged the mother board by not switching off the power? And, what would  test/fix would you recommend?
I'd bet you have blown the output fuse
Blown a fuse in the main controls.
When was the last time the system was serviced? Maybe worth considering having a service if it's been a while.
