Risco LightSYS 2 and a new router
Anyone had issues with panel not connecting to the cloud when the ISP and router is changed to a new provider?  Home hub and everything else connects apart from alarm, any advice appreciated.
So panel connects to router ok?
Lots of problems with latest BT home hub and some CCTV recorders. We had a problem with plusnet too, with HKC cloud
yes no problem and we can ping the IP address, have tried static IP and now gone back to dynamic.
I have no idea with this kit just guessing
Do you need to release anything cloud side?
connected originally on ADSL plusnet router with static WAN IP now upgraded to fibre and using a VIGOR DrayTek
may be need to do a clean install and hope that resets everything.
You ping from external connection to the port or just the ip.?
no internally from a computer to the IP address
So not proved then
