galaxy bell wiring
Hi i am trying to connect a FPDELTAX3MOD Deltabell X G3 Module, (backlit, twin piezo) to a galaxy dimension 48 ( have moved jumper on bell to G2) have tried it couple of ways into rio 0 with std galaxy setting, could do with correct wiring (or bell goes of when closing bell lid), i have follow info in post below any help would be really greatfull thanks.
G3 module as I myself helped by an alarm monkey is looking for power on the trigger you need a resistor there , look at drawings / instructions again
IIRC they require pull up resistors for the bell trigger, when absent or wrong value its sounds when you close the tamper.
Oh Yeah that's what you call it
+1
