dave36 Posted December 2, 2018 Share Posted December 2, 2018 Hi Hope that someone can help - I've just moved into different premises and there is a galaxy 48 on the wall, but all the cables had been disconnected. Well I've figured out the keypads and the detectors but there is a six core cable going to the bell box and I am having trouble with it to say the least! Obviously (I think) that red is +VE and black is 0v, blue and white seem to be tamper which leaves green and yellow. But when I connect them the siren either remains silent or goes off constantly. So am I connecting to the correct place? the RIO outputs, or do I need to fit resistors? Apologies if this is a stupid question. all my previous alarms were far less complicated :-) Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42539-galaxy-48-external-bellsirenbox-connections/ Share on other sites More sharing options...
GalaxyGuy Posted December 2, 2018 Share Posted December 2, 2018 You really need to open the external siren to note the connections. No resistors are required, so it's likely that your guess at the wiring isn't correct. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42539-galaxy-48-external-bellsirenbox-connections/#findComment-480895 Share on other sites More sharing options...
dave36 Posted December 3, 2018 Author Share Posted December 3, 2018 (edited) Hi Green wire to str, yellow to bell, red and black to + and - blue and white to T under that there are some jumpers pos/neg, sab/sbc batt sel int/ext although the bell doesn't have a manufacturer on it the pcb is marked RPCB488 v H Edited December 3, 2018 by dave36 Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42539-galaxy-48-external-bellsirenbox-connections/#findComment-480907 Share on other sites More sharing options...
james.wilson Posted December 4, 2018 Share Posted December 4, 2018 we can identify it from a pic but bell is the trigger so that will go to an output programmed as bell t is the tamper return securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42539-galaxy-48-external-bellsirenbox-connections/#findComment-480920 Share on other sites More sharing options...
dave36 Posted December 4, 2018 Author Share Posted December 4, 2018 so here is the pic of the bell box, but I think its knowing where to put the wires in the galaxy 48 that the issue. Also I presume I have to program the galaxy outputs ? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42539-galaxy-48-external-bellsirenbox-connections/#findComment-480930 Share on other sites More sharing options...
james.wilson Posted December 4, 2018 Share Posted December 4, 2018 a zoomed out one? yes you will need to program 2 outputs. One as bell the other as strobe securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42539-galaxy-48-external-bellsirenbox-connections/#findComment-480931 Share on other sites More sharing options...
al-yeti Posted December 5, 2018 Share Posted December 5, 2018 11 hours ago, james.wilson said: a zoomed out one? yes you will need to program 2 outputs. One as bell the other as strobe No outputs default? I suppose op probably changed them anyway 11 hours ago, dave36 said: so here is the pic of the bell box, but I think its knowing where to put the wires in the galaxy 48 that the issue. Also I presume I have to program the galaxy outputs ? So this is a deltabell? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42539-galaxy-48-external-bellsirenbox-connections/#findComment-480942 Share on other sites More sharing options...
al-yeti Posted December 5, 2018 Share Posted December 5, 2018 On 03/12/2018 at 14:04, dave36 said: Hi Green wire to str, yellow to bell, red and black to + and - blue and white to T under that there are some jumpers pos/neg, sab/sbc batt sel int/ext although the bell doesn't have a manufacturer on it the pcb is marked RPCB488 v H Blue tamper , can't see what white is doing though Have you got a picture on the 48 side I have feeling your connected to wrong connections Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42539-galaxy-48-external-bellsirenbox-connections/#findComment-480943 Share on other sites More sharing options...
GalaxyGuy Posted December 5, 2018 Share Posted December 5, 2018 This is the wiring on a Dimension with default programming for outputs 1001 (bell) and 1002 (strobe) Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42539-galaxy-48-external-bellsirenbox-connections/#findComment-480946 Share on other sites More sharing options...
dave36 Posted December 5, 2018 Author Share Posted December 5, 2018 That's great many thanks I will give this a go - where does the white tamper wire go - into the 0v ? with the black Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42539-galaxy-48-external-bellsirenbox-connections/#findComment-480978 Share on other sites More sharing options...
