November 11, 20187 yr comment_480585 Hello, I'm sure it is possible but am struggling to find out how to do it. I would like the bellbox to display a form of flashing LED when armed. I would be grateful for any support or guidance with this. Thank you Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42506-pyronix-enforcer-bellbox-comfort-strobe/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
November 11, 20187 yr comment_480586 EN50131 says there should be no visible indication to show that an alarm system is armed, so I would think it highly unlikely that it is in the programming of any system, even Pyronix Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42506-pyronix-enforcer-bellbox-comfort-strobe/#findComment-480586 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
November 12, 20187 yr comment_480588 The comfort LEDS are either enabled or disabled and that’s it. There is no input to trigger them. The status is determined by a link on the siren pcb. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42506-pyronix-enforcer-bellbox-comfort-strobe/#findComment-480588 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
November 12, 20187 yr comment_480590 Are you looking for the strobe to give you conformation of setting /unset coopers panels can give you a 3 strobe flash on both so might be in setting progg www.AllanMoncrieffAlarms.com Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42506-pyronix-enforcer-bellbox-comfort-strobe/#findComment-480590 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
November 12, 20187 yr comment_480595 19 hours ago, Gav1978 said: Hello, I'm sure it is possible but am struggling to find out how to do it. I would like the bellbox to display a form of flashing LED when armed. I would be grateful for any support or guidance with this. Thank you Or your basically using a wireless bellbox and it has no flashing LEDs in general Only option is to put in a wired bell Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42506-pyronix-enforcer-bellbox-comfort-strobe/#findComment-480595 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
November 12, 20187 yr comment_480596 40 minutes ago, al-yeti said: Or your basically using a wireless bellbox and it has no flashing LEDs in general Only option is to put in a wired bell The Pyronix wireless bell box has the option to enable/disable ‘comfort’ flashing LED’s. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42506-pyronix-enforcer-bellbox-comfort-strobe/#findComment-480596 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
November 12, 20187 yr comment_480597 Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42506-pyronix-enforcer-bellbox-comfort-strobe/#findComment-480597 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
November 12, 20187 yr comment_480600 1 hour ago, Amps said: The Pyronix wireless bell box has the option to enable/disable ‘comfort’ flashing LED’s. Battery's last long? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42506-pyronix-enforcer-bellbox-comfort-strobe/#findComment-480600 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
November 12, 20187 yr comment_480602 1 hour ago, al-yeti said: Battery's last long? Dunno. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42506-pyronix-enforcer-bellbox-comfort-strobe/#findComment-480602 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
November 12, 20187 yr comment_480606 46 minutes ago, Amps said: Dunno. Ah ok, was going to compare with hkc, they have additional battery pack gives you 24-36 months approx depending on flash rate , otherwise single normal pack will give you 6months Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42506-pyronix-enforcer-bellbox-comfort-strobe/#findComment-480606 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
