Galaxy 16 Plus Communications Conundrum
if you use home3 / home4 numbers iirc these will dial a phone there  are 4 different tones depending on the alarm event
  • Replies 31
  • Views 8.8k
  • The Arab
    The Arab
    If the phone line wasn't connected before you started it may be that the system has been hit by lightning so disconnected, you can check this by doing a continuety test with a multi meter check betwee
  • james.wilson
    james.wilson
    if you have programmed the digi side it won't work direct to a phone
  • As above you said you entered the phone number, that com device is not a dialler like a speech dialler so won't do what you want it to do   You will need to buy a stand alone dialler to conn
An impressive memory James and quite right. I have entered the mobile number for Home 3 and adjusted the Triggers so only Intruder will activate the call.
Unfortunately I still haven't been able to get around the problem I was experiencing initially, that as soon as I plug the phone line into the alarm system, the phone line becomes constantly engaged (if I pick up a normal phone I can hear a constant tone).
I have tried deleting the main account number and phone number, since I am not using them and the manual says that it will dial Home 3 when it gets a Comm Fail from the main line.
So I would have assumed the call to the main number fails -> then I get the 'tone' call to my mobile. Any ideas, why it is constantly engaged? Is the connection correct (I have re-posted photo below)? I know this set up was working with the previous owner who had a maintenance contract with the installer so had assumed this wasn't the problem.
Richard.
Is the digi set up as dual reporting? Change it to single,put a dummy account in and telephone number,set fail to comm to 1 and number of rings to 20 restart panel and try again..
Thanks goncall. I've entered the settings as you said and input dummy account and phone number. Hopefully a simple question... how do you restart panel?
whats plugged into the phone socket on the panel?
I was hoping there would be a restart button. I've turned the power off at the fusebox and the control panel is still being powered by the battery I assume. Is there an easy way to disconnect it? I've tried pliers but nothing shifted and don't want to get too hands on as not sure how safe that would be. Attached a photo of the battery, which I assume I need to disconnect to reset the panel...
