April 30, 20188 yr comment_476432 Hi All, Needed a bit of advise. Had a new aluminium front door installed. The previous wooden door had a flush contact sensor. I've attached a photo. I needed a new sensor that would be on the surface rather than flush. Not quite sure what to get. Originally it was a CQR MAXIMAL FLUSH CONTACT FC504 O.G 23MM. Can anyone point me in the right direction on what to replace it with? Will this do the job? https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F261754615766 Any help will be greatly appreciated. Titch Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42083-change-of-door-sensor/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
April 30, 20188 yr comment_476433 Can you not fit another flush? You can get tiny ones like fc503that work well in aluminium doors. Surface looks gash IMO. https://www.cqr.co.uk/contacts/flush-contact/ Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42083-change-of-door-sensor/#findComment-476433 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
April 30, 20188 yr Author comment_476434 I agree. I just thought it would be trickier as the door hasn't got a flat surface to mount on. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42083-change-of-door-sensor/#findComment-476434 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 1, 20188 yr comment_476437 The pencil type ones deal with that better. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42083-change-of-door-sensor/#findComment-476437 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 1, 20188 yr comment_476440 Any type of contact could work If you can fit within the operational gap but the push in "pencil style" are normally the most aesthetic on alu. I keep a few GE ones handy (1078). A picture of the door maybe handy if you need more advise on a surface fit. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42083-change-of-door-sensor/#findComment-476440 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 1, 20188 yr Author comment_476443 Thanks for the response. I definitely think the flush ones are the way to go. Maybe it's time for a full install. The system is a bit dated anyhow. I think I need to get the professionals in. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42083-change-of-door-sensor/#findComment-476443 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 1, 20188 yr comment_476444 Sensible decision. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42083-change-of-door-sensor/#findComment-476444 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 9, 20187 yr comment_478470 Sorry If I am a bit late as I had new windows and doors installed. This was the perfect time to route the wires in and into the flush fit magnets. Did they cut the wires when the door was installed? Could you get to the wire or have some one connect to that wire access with the new door? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42083-change-of-door-sensor/#findComment-478470 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
