Sd1+ help
Guys
i havent installed a sd1+ for a few years now but i did one for a friend. On the sd1 dialler do i wire it to A or o/p1 (next to 12v supply)?
I’ve had a memory loss lol but didnt want to blow it.
Thanks
Just a guess but o/p1 will be an output, not an input...
What are you wiring and didn't it come with a  manual?
1 hour ago, Ghost said:
Guys
Thanks
Trigger A yes , (NOT A for phone line )
Just be sure to record message A correctly
Thanks
i just left a message on phase 0. I’m wiring it off a G2-12 galaxy.
But when I wired it to A it was ok but when we set the alarm it was calling. So it calls when bells trigger and when we set
  • 3 weeks later...
On 3/11/2018 at 08:14, Ghost said:
Thanks
where is trig a wired into on the galaxy? probably need to change output type from calling when set
Thanks
Just connect the trigger to the bell trigger
