February 26, 20188 yr comment_474845 Hi all: I have been installing Texecom Premiere Elite 48 (wired) for a while with great success and reliability. I now need to install a wireless alarm as I have come across a property where running the cables with be too difficult. As I know Texecom very well I am looking into install their wireless alarm, specifically the 64-W Kit-0002 with a few add-ons (panic button etc). Can anyone please give me their experience of how reliable this system is? Any advice... Thanks v much Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41974-texecom-premiere-elite-wireless-64-w-reliability/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
February 26, 20188 yr comment_474846 ive got some out there, and on the whole they are very good. the only issue i have found is if your sab signal is low, it will drop in and out, causing it to continually poll, which the kills the batteries. if you can hard wire the bell i would. apart from that no dramas Edited February 26, 20188 yr by mjvesq1969 Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41974-texecom-premiere-elite-wireless-64-w-reliability/#findComment-474846 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
February 26, 20188 yr comment_474849 Installed correctly as per the instructions you shouldn't have any issues. If you don't know what you are doing you are likely to have endless polling errors and headaches. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41974-texecom-premiere-elite-wireless-64-w-reliability/#findComment-474849 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
February 26, 20188 yr comment_474854 3 hours ago, mjvesq1969 said: ive got some out there, and on the whole they are very good. the only issue i have found is if your sab signal is low, it will drop in and out, causing it to continually poll, which the kills the batteries. if you can hard wire the bell i would. apart from that no dramas Doesnt it give signal level readings? Then fit repeater where necessary This is where I like the hkc RF wand, you can measure every point where it can be a problem Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41974-texecom-premiere-elite-wireless-64-w-reliability/#findComment-474854 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
February 26, 20188 yr comment_474857 the texecom dosent give signal readings, not that i could find anyway...i wouldn't want to use a repeater on a sab. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41974-texecom-premiere-elite-wireless-64-w-reliability/#findComment-474857 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
February 26, 20188 yr comment_474863 It does and there are no repeaters it's mesh. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41974-texecom-premiere-elite-wireless-64-w-reliability/#findComment-474863 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
February 26, 20188 yr comment_474864 1 hour ago, mjvesq1969 said: the texecom dosent give signal readings, not that i could find anyway...i wouldn't want to use a repeater on a sab. You know what your doing yeah? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41974-texecom-premiere-elite-wireless-64-w-reliability/#findComment-474864 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
February 26, 20188 yr Author comment_474865 7 hours ago, mjvesq1969 said: if you can hard wire the bell i would. Hi thx, the kit comes with the Odyssey X-W . I do think I can find a route for the bell, do you know if this bell allows for hard wire (in addition to wireless)? Also have you used the PIRs that come with this kit? The Premier Compact PW-W. the ones I've used on my wired installations have been great and hoping these are regarded as good PIRs too? Thanks again Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41974-texecom-premiere-elite-wireless-64-w-reliability/#findComment-474865 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
February 26, 20188 yr comment_474866 No, you need to select a wired or wireless bell they do not do both. Kit ones are normally the basic version of the PIR, not the Elite QD or DT versions which are better. Basically most of the wireless kits provide a budget option to try to compete with other manufactures kits. If you want to pick you would have to buy individually. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41974-texecom-premiere-elite-wireless-64-w-reliability/#findComment-474866 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
February 26, 20188 yr Author comment_474869 22 minutes ago, sixwheeledbeast said: No, you need to select a wired or wireless bell they do not do both. Kit ones are normally the basic version of the PIR, not the Elite QD or DT versions which are better. Thanks. I have Elite QD (wired) in all my installations and they work great, never had an issue with them. It is annoying as I can't get a bundle that fits what I need which includes: wireless panel + 3x QD-W PIRs + Wired Bell. Having not used the basic PIRs before I am tempted to buy the Kit-0001, add a wired bell, wireless PA, and dialer. Do some long run tests on that and switch out for the QD-W at a later date (if required). Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41974-texecom-premiere-elite-wireless-64-w-reliability/#findComment-474869 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
