ADE Optima Compact "clicking" and dim power lights after mains power off
4 hours ago, norman said:
Why would they not work?
Chinese gear can be temperamental or hacking jbeye stuff for hostile take over
No reason why it wouldnt. We have never used this kit before so we wanted to set it all up and test it, while we were at it we programmed the system the same as what it was going to be when installed. It saves the engineers getting flustered on site, all they have to do is install the kit and the sw,  run a backup and the system will work. The customer can pre issue the fobs safe in the knowledge that they are programmed and tested.  Staff will get in all doors tenants only the ones they're allowed to get in.
The readers and fobs are secure format so I also wanted to be sure that they were all programmed correctly too. I am fairly happy that the kit is reliable as I have been reliably informed that from trusted sources that it is.
