Eavesy Posted February 2, 2018 Author Share Posted February 2, 2018 Ok thanks for the replies... any ideas as to what I should do first in order to sort the issue.... after completing the power off and removal of lead from battery in panel only the back box sounds so I assume the battery in front box is dead.... but I assume this bell box shouldn’t work off mains anyway.... Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41905-veritas-8-bell-box-issue/page/2/#findComment-473910 Share on other sites More sharing options...
sixwheeledbeast Posted February 2, 2018 Share Posted February 2, 2018 Both boxes should sound if power is removed, this is not powered from the mains. However if in Hold-Off mode the bell will not sound anyway so this doesn't prove the battery. Your next steps are deciding if you competent to diagnose what is wrong with it, I am assuming its just a tamper fault somewhere but you need to test it with a meter and work it out. The easy way to fix it from a DIY perspective if the field wiring is ok would be to buy two new boxes they will come with colour for colour instructions. It's likely something an engineer could repair and maybe a service check wouldn't go a miss to aid system reliability, so it's you decision on which way you wish to go. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41905-veritas-8-bell-box-issue/page/2/#findComment-473913 Share on other sites More sharing options...
al-yeti Posted February 2, 2018 Share Posted February 2, 2018 4 hours ago, Eavesy said: Ok thanks for the replies... any ideas as to what I should do first in order to sort the issue.... after completing the power off and removal of lead from battery in panel only the back box sounds so I assume the battery in front box is dead.... but I assume this bell box shouldn’t work off mains anyway.... I would say if you have time make a note of how it's wired, written and pictures Then wire up front bell as a single unit and try and get it to work Or if you really think it's front battery , change it, it's cheap And as above can you do this right... Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41905-veritas-8-bell-box-issue/page/2/#findComment-473924 Share on other sites More sharing options...
