16ch Qvis Quattro V2 restarting
Hi All,
I was wondering if anyone had any ideas on an issue ive had today.
I have upgraded an existing CCTV System from an old PC based system to a DVR but the DVR is restarting around every 10 mins.
I have disconnected all monitors bar my test monitor and it still did it
changed the HD
removed the HD
changed the power supply
changed the password
Camera wiring remains original and I'm thinking I could maybe have some power coming up one of the existing cables which over loads the dvr in some way and restarts it.
Any ideas before I give in and call support
Thanks
12 minutes ago, PeterJames said:
psu probably, are you sure that you have used the one that came with the recorder?
Init
100% the one that came with the recorder unfortunately, ill take it back today.
Thanks
yes I always buy barebones kit and install my own drives. It has had three different HD installed
It is going back to supplier today for a replacement.
I would have said exactly the same but I tried a new one out of a spare I had and it still restarted. Returned it to the supplier and replaced it with a Viper which has been faultless since :)
Thank you for your ideas and help guys
  • 4 weeks later...
What app on mobiles does the qvis range use and how stable I'd the app to the DVRs
07475071344
  • 3 weeks later...
Sorry i have only just seen this.
It depends which DVR you are using, i have systems on the Explorer App and Super Live Plus, i find both reliable.
