False alarm issue
Just wondering if any one has ever had an issue with the old style Honeywell dt755 , all the detectors I have in use are these but I have one that keeps false alarming only when large vehicles seem to go past (cctv checked at activation times ) all voltages and resistances readings are fine device replaced set on its lowest sensitivity setting still happens at a bit of a loss to be honest
Edited by Ashton
  • Replies 32
  • Views 6k
  • datadiffusion
    datadiffusion
    Could have been an MI5 / TV detector van shifting a recently crashed UFO across the county whilst trying to stop Trump publishing details of Kennedy...?
  • does the alarm relay also open on AM ?   is the sensor nr a door ?
  • Just found it 24.200ghz miles out
Weird thing is aswell on 2 of the activations the same van went past was wondering could it be some sort of rf interference ?
Edited by Ashton
:lol: I'm siding with the MI5 theory tried changing cores on cable panel has an ac suppressor fitted tried changing Cct from panel to local expander its calmed down a lot since changing sensitivity level (dropped microwave to low level and selected dip switch 1 to Lower setting) but still happens now and again the van theory came from thinking it must be environmental but trying to narrow down what happened at point of activation and only thing in common is large removal vans/council trucks go past all connections re made when I changed the cores
distance wise from the vehicle aspect Is a good 10-15 meters out of the window to a facing mini round about
And them tv detection vans how ever did they know I was picking up a tv signal :lol:
Was just after something to go at I know a number of years ago the Honeywell elephant catchers had An issue with beacons/strobes on forklifts etc sending them into a tamper condition just wondered if there was something with the Honeywell 7550 I'm unaware about
Have you tried swapping one with another to see if the fault moves to the other room?
only the guts not the whole thing.
i had these in my old house for years and never had any problems.
Hi I have tried 3 different boards but not actually swapped them around with each other and I know I have these in all rooms and they are usually bullet proof so that's why I'm struggling with this issue
