Texecom Premier Elite 24
Hi everyone, I'm new to the site so hope I'm posting in the right place!?
I have a Texecom premier elite 24 alarm installed by a friend, who works for a security company, but is unreliable and isn't getting back to me with the questions I need answering.
long story short is the alarm texts me for events, I really want it to call me instead, what comms module or speech dialler do I need?
Hope this makes sense and I look forward to your help.
Oliver.
  • Replies 29
  • Views 8.1k
  • installer_dale
    installer_dale
    As u already have the com2400 then u can add the speech module to it (goes inside the panel) which allows it to ring you instead of only texting.   The speech dialler and speech and text dia
Texecom CGE-0001
Both are considered poor methods of alert in professional circles, mind.
Edited by datadiffusion
What are the best best methods? I think he put a com2400 in the panel, guess this only does text?
Proper paid for monitoring, as if your line gets cut you won't get notified.
However, TAP Text notification really is the worst of the worst as even if the line is intact the message failure rate is terrible.
Any cheap old dialler in combination with the com24 will work, keep the sms
+12 to +12
Ov to 0v
Trig to  -bell trigger
In most diallers
Texting gives you so much more information though.  If possible change the sms sound for that contact to make sure it gets your attention.
Does the speech module still work with the new elites? I'm sure I read somewhere it was being phased out.
Edited by installer_dale
If I add the CGE-0001 in connection to the com 2400, should it ring and text me at the same time?
I google speech dialler, and the results seem to come up with the the panel for around £80!?
Price is about right
I meant keep using the com2400 as it is and add the dialler for dialling only
I'm sure he fitted a PSD-001, and connected the phone line to the com2400 in the main panel, yet all it does is text me, and even that isn't brilliantly reliable
I want a phone call, and then an SMS unit separate in case phone line is cut,
