POC Posted July 14, 2017 Share Posted July 14, 2017 Hoping someone here can help me! Roughly 12 months ago I had our existing alarm replaced with the EURO 46, all has been fine until last week. The white metal box (control panel?) started making a low buzzing noise, but all continued to function ok. Couple of days ago the keypad started warning that the battery in the control panel wasn't charging, then battery critical, now its saying low volts, at this point the buzzing has stopped! I'm struggling to find someone to come take a look. Any ideas? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41396-euro46-woes/ Share on other sites More sharing options...
MrHappy Posted July 14, 2017 Share Posted July 14, 2017 26 minutes ago, POC said: Roughly 12 months ago I had our existing alarm replaced with the EURO 46, all has been fine until last week. warranty ? Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41396-euro46-woes/#findComment-465908 Share on other sites More sharing options...
datadiffusion Posted July 14, 2017 Share Posted July 14, 2017 50 quid says either existing battery re-used, new from Maplins, or just a 2nd hand battery which has failed nearly taking PSU with it. So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41396-euro46-woes/#findComment-465910 Share on other sites More sharing options...
norman Posted July 14, 2017 Share Posted July 14, 2017 Do you have a smoke alarm nearby? 1 Nothing is foolproof to a sufficiently talented fool. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41396-euro46-woes/#findComment-465911 Share on other sites More sharing options...
POC Posted July 14, 2017 Author Share Posted July 14, 2017 27 minutes ago, MrHappy said: warranty ? Possibly on the hardware, the install was a cash job, the relationship has since soured. 17 minutes ago, datadiffusion said: 50 quid says either existing battery re-used, new from Maplins, or just a 2nd hand battery which has failed nearly taking PSU with it. You think a straight replacement battery will solve the problems? Surly I can do this myself? 17 minutes ago, norman said: Do you have a smoke alarm nearby? I have a nest protect smoke alarm approx 8ft away. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41396-euro46-woes/#findComment-465912 Share on other sites More sharing options...
datadiffusion Posted July 14, 2017 Share Posted July 14, 2017 55 minutes ago, POC said: the relationship has since soured. You think a straight replacement battery will solve the problems? Surly I can do this myself? OK; do you have the engineer code? So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41396-euro46-woes/#findComment-465913 Share on other sites More sharing options...
POC Posted July 14, 2017 Author Share Posted July 14, 2017 (edited) 1 minute ago, datadiffusion said: OK; do you have the engineer code? Yes, I have the engineer code ) Edited July 14, 2017 by POC Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41396-euro46-woes/#findComment-465914 Share on other sites More sharing options...
MrHappy Posted July 14, 2017 Share Posted July 14, 2017 place into eng, open lid remove battery lead if system remains powered try a replacement battery if not its fuse /transformer ect... Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41396-euro46-woes/#findComment-465915 Share on other sites More sharing options...
POC Posted July 14, 2017 Author Share Posted July 14, 2017 34 minutes ago, MrHappy said: place into eng, open lid remove battery lead if system remains powered try a replacement battery if not its fuse /transformer ect... Great thanks, do you know what battery I'll need? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41396-euro46-woes/#findComment-465918 Share on other sites More sharing options...
datadiffusion Posted July 14, 2017 Share Posted July 14, 2017 I assume 7ah, buy a quality make like Genesis or Yuasa, avoid Chinese no-name or 'Lucas' ones from eBay. So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41396-euro46-woes/#findComment-465920 Share on other sites More sharing options...
