June 18, 20179 yr comment_464456 Hello I have reset a panel which has been down for around 1 month after the panel went off in the middle of the night and the fuses and battery was removed I have tried to default the panel to factory settings and after doing so the screen has come up strange on keypad 1 there is 4 keypads on this panel before defaulting we were not able to do anything at the keypads some said System Init and the others said System Busy and would not clear even with a manager code Any ideas what to do from here I'm thinking possibly the panel is knackered and I should change this just before I do I would like to get some simple advise do you think there has possibly been a power surge which has damaged the panel ? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41312-karisma-plus-panel-reser/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 18, 20179 yr comment_464460 who'd have thought a 20 yr alarm panel would be playing up... remove a rkp off the wall, connect via a flylead to the panel with no other rkp on the system & try to default apart from 4 rkp what else is on the system Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41312-karisma-plus-panel-reser/#findComment-464460 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 18, 20179 yr Author comment_464464 Ok Great thanks I think I'm going to swap this out with a Gardtec/ Risco Group 595 panel or sonething that I am familiar with ! i seen people talking about the Karizma Plus panels the door contacts and Shock sensors possibly having biscuit ID how do I check if this is the case ? I will I'll try the keypad that you say there is about 30 shock sensors, 10 door contacts and a few PIRs and 4 RKPs and 1 bellbox Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41312-karisma-plus-panel-reser/#findComment-464464 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 18, 20179 yr comment_464465 just an endstation & no PSU's ? Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41312-karisma-plus-panel-reser/#findComment-464465 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 18, 20179 yr Author comment_464466 Yes there is 2 Psu's 1 in the panel & another above Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41312-karisma-plus-panel-reser/#findComment-464466 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 18, 20179 yr comment_464467 30 minutes ago, JDB Solutions said: i seen people talking about the Karizma Plus panels the door contacts and Shock sensors possibly having biscuit ID how do I check if this is the case ? There's no DP or EOL circuits its all iD If you've not touched iD before... cost to rewire it'll be cheaper than fault finding 20yr old iD circuits Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41312-karisma-plus-panel-reser/#findComment-464467 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 19, 20179 yr comment_464469 Yep needs iD compatible kit or a full system if you can't get it working again Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41312-karisma-plus-panel-reser/#findComment-464469 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 19, 20179 yr comment_464481 You will need the Gardtec 601panel as this can take 2 x expander boards or use a panel that does BUS wiring. Edited June 19, 20179 yr by Hillbilly Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41312-karisma-plus-panel-reser/#findComment-464481 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 19, 20179 yr comment_464483 BUS is another option, yes Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41312-karisma-plus-panel-reser/#findComment-464483 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
