EUROSEC CPX CP8L KEY PAD
Scantronic no good for wireless at the moment, Visonic 1 way too, as above Texe would be fine.
  • Replies 111
  • Views 35.3k
  • karl taylor
    karl taylor
    Have spoken to a company in my area this morning, very helpful. They have said exactly the same as you  i need to check zone settings . they can come out and sort it in 10 minutes but have suggested i
  • Just realised what keypad it is, yeah scrap whole system or fit to shed only
  • well.... Texecom radio stuff is almost as bad as Risco   Start deleting & changing devices & you soon find the menus are all over the place & far from logical
A alarm company that is a gold installer recommended scantronic and visonic as thats what they fit. I wont be fitting the system as haven't got the time. So just weighing up my options and in the meantime trying to put right what i have to keep the mrs happy
if they want to support it then fine, I wouldnt.
Diy rf wise i has to be texecom. If i was installing it would be hkc.
Got to email back another approved gold installer to see what they fit. The plot thickens. I get there in the.  I might just get a dog instead lol.
get them and upload tmem, most is opinion and experience. You had a risco user reply and help you out.
Then we can give our thoughts on them
Ok will do.
Just need a few other risco users to read this and my question on comments on noise rf interference. And my readings i have found before i go any further with my rover metro vanden plas GTi lol.
Thanks all for your input.
best of luck
it was a gta btw
On 6/10/2017 at 9:36 PM, karl taylor said:
Yes agree with all comments made.
I get some one out next week i think as its got to be programming issue now.
Alarm off,  open landing window.  Full house alarm goes off.  Panic zone 093.
So i remove zone 093 off system and reset it. Then
 I  created  a new zone zone 097 but i dont know what the default settings should be for that wireless zone,  however when i open the landing window and alarm is off it fine.
So do i leave landing window set as zone 097 but what the default settings are i dont know or do i try and ammend the settings for zone 093 which would keep it as it was with the correct zones etc.
Since i have limited kniwledge on how to change zone parameters i think it is niw best i get some one in to ammend the settings before i knack it up . Or pull the plug on it and up date the system
 Can you not go through the engineer menu and change the attributes of zone 097 and make it 12hr?  You can find the manual on the risco website as you will hear a million times when ringing the risco technical support line!
Brad Jackson
Techvision Security Group
Hi Brad . Yes have changed the settings now on the panel to correct settings .
I just need to address why i am getting two wireless sensor dropping off and loosing signal . was advised to check out rf interference and measure it on the panel but no info is available on how to do it and dont want to mess this up . settings that are written down in user manual says at point of install the following=
Before i start looking in to changing reciever noise etc the original set notes written in the manual say:
Reciever noise 13%
Zone RSSI
Back door. Zone  91  -  64%
Patio door zone 92 -  80%
Landing window zone 93 -  80%
Bathroom window zone 94 -  80%
Small shed zone  95 -  56%
Large shed zone. 96 -  56%
so if these settings are ok i leave it well alone .............?
have been recommended either a  Texecom and Pyronix systems both with an option of wired or wireless,
are these any good ?  to a replacement of my Eorosec cpx ..........?
