Texecom com wifi
Hi
I've installed a complete wifi and managed to get it working on the app but it won't connect remotely. I've set up the port forwarding on bt smart hub but it's still the same.  I've spoken to texecom and get the same answer it's the port forwarding!! I'm wondering whether I've missed something somewhere.
I'm totally at a loss now and would appreciate any help!! Thanks in advance..
  • Replies 37
  • Views 12.2k
  • sixwheeledbeast
    sixwheeledbeast
    If it's open then it's likely a setting in the app or the settings in Program Digi then.
  • sixwheeledbeast
    sixwheeledbeast
    Probably No
  • sixwheeledbeast
    sixwheeledbeast
    Gateway is the IP of your gateway, DNS is the IP of the DNS server. If using a BT router these are likely to be that.     Probably not advised if you have no networking skills. I
It sounds like port forwarding, I would assume the router isn't setup correctly.
  • Thanks for the reply.
It's on 10001 tcp and set to the ip address linked to the com wifi I've even tried renaming it. I've deleted and done it again several times. It's weird it's as if the bt smart hub is not so...
Edited by Foote1234
Mistake
I think I did that and it said it was. Can you remind me again please.
Yeah just checked it's open
I'm wondering whether it's set to the internal ip somewhere as I can't connect remotely
It's a v3 panel will that make a difference?
Oh golly I'm adding one of these on a premier 24 elite panel on Monday,
my first time! Any tips appreciated.
Don't even know where to start on these things yet.
Thrones
