karl taylor Posted February 16, 2017 Share Posted February 16, 2017 Hi all , thanks for your help on my past post. The issue is I need help with is on the control panel on event log it is saying what i believe are faults but i would like to know if any one could tell me what they mean please system was installed in 2011. it is a eurosec cpx lcd key pad . it is a risco c CPX with a gardtec 8 zone wireless expander I have looked on the system log for events / issues it says the following= Looking at system event view it says patio door o. Also reads 27th jan off chg.volts lo 19th jan radio lo bat ok Patio door o. 19th jan at 00 28 Patio door o. 19th Jan at 00 27 9 jan constant lo bat at 21.00 does any one know what these events / faults mean more so what off chg. volts lo and constant lo battery ? any help welcome again please . Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40966-risco-cpx-event-issues/ Share on other sites More sharing options...
al-yeti Posted February 16, 2017 Share Posted February 16, 2017 Low battery? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40966-risco-cpx-event-issues/#findComment-458906 Share on other sites More sharing options...
karl taylor Posted February 16, 2017 Author Share Posted February 16, 2017 Dont know? Would this trigger an event all the time or just once? If the units battery was knackered would this not show up all the time on the panel on event log Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40966-risco-cpx-event-issues/#findComment-458911 Share on other sites More sharing options...
karl taylor Posted February 16, 2017 Author Share Posted February 16, 2017 On event log it says this now: Constant lo bat 13 feb 15:00:00 Radio lo bat ok 15 feb 19:18:16 Off chg volts lo 27 jan 19:06:20 Radio lo bat ok 19 jan 19:41:36 Power restored 10 jan 21:09:36 Constant lo bat 09 Jan 21:00:00 Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40966-risco-cpx-event-issues/#findComment-458913 Share on other sites More sharing options...
karl taylor Posted February 16, 2017 Author Share Posted February 16, 2017 Any thoughts please apart from scrap this over complicated out of date joke of a alarm system. Not impressed. Do i need a new panel battery? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40966-risco-cpx-event-issues/#findComment-458915 Share on other sites More sharing options...
al-yeti Posted February 16, 2017 Share Posted February 16, 2017 Have you measured the battery voltage with good meter , not Chinese stuff that will give you wrong readings For the sake of £4 change battery see what happens Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40966-risco-cpx-event-issues/#findComment-458916 Share on other sites More sharing options...
karl taylor Posted February 16, 2017 Author Share Posted February 16, 2017 hi where is the best place to buy a good quality battery for this alarm control panel ? just need to remove front cover and reset tamper then unclip it and fit new one ? don't think any thing special about doing this > I don't need to reset it on the system so alarm knows it has a new battery for correct trickle charging ? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40966-risco-cpx-event-issues/#findComment-458918 Share on other sites More sharing options...
MrHappy Posted February 16, 2017 Share Posted February 16, 2017 1 hour ago, karl taylor said: hi where is the best place to buy a good quality battery for this alarm control panel ? from an alarm co. one who familer with your product would probably change the al the battery monitoring option to the highest & lowest settings all the radio sensor batteries require replacing too Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40966-risco-cpx-event-issues/#findComment-458925 Share on other sites More sharing options...
karl taylor Posted February 16, 2017 Author Share Posted February 16, 2017 Have change the 5 wireless batteries on the wireless sensors last month. What other batteries are there apart from them and one in panel Why do i need to change them again?. How do i change the battery monitoring options to highest and lowest settings on this panel? its not a user friendly system. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40966-risco-cpx-event-issues/#findComment-458927 Share on other sites More sharing options...
MrHappy Posted February 16, 2017 Share Posted February 16, 2017 (edited) says radio low battery 15th feb..... you using remote fobs (not prox tokens) ? battery monitoring options are under diagnostics ? low is 11.8 & high is 14.2 IIRC ? Edited February 16, 2017 by MrHappy Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40966-risco-cpx-event-issues/#findComment-458928 Share on other sites More sharing options...
