Ade Gen 4 Alarm Help
I removed the front panel of my ade Gen 4 home alarm without the engineer code to adjust the exit tone volume now the tamper light continues to flash I have tried putting my password and pressing reset but it's not working, I don't have the engineer code! Any ideas how I can rectifiy this problem without resetting the whole system.
  • Replies 29
  • Views 6.5k
  • Created
  • Last Reply
put the lid back on properly before trying to reset
The lid has been screwed back securely and the tamper is still flashing. I thought it would be easy enough to do take place panel off adjust sound out put panel back on input my code and reset, I see this not the case.
Edited by Sweety25
you still have a tamper problem then, either you have another tamper or the sping isn't closed
he tamper switch that is detecting if the lid is on correctly
I think your right it's set up for the engineer to reset after tamper! I can't see no another reason why it would not go back to normal settings. Will give them a call tomorrow.
