Fire at clandon park
WDT
I know people have discussed fire and stuff on here, A friend of mine who was a fireman on scene that day of the clandon park fire thought i might like to look at the report as we have talked about how they work out the cause of a fire, I also thought some of you guys may like some light bed time reading and there is photos at the end,
http://www.surreycc.gov.uk/people-and-community/surrey-fire-and-rescue/surrey-fire-and-rescue-services-fire-investigation-report-clandon-park
Loose N. That's how an otherwise very good electrician friend of mine cause £1m+ worth of damage to a new-build nightclub that hadn't even opened.
He forgot to tighten the N nut on the main busbar and then as the occupier moved in and ramped up the load...
Amendment 2 calls for metal boards to contain fire due to loose connections on domestic installs....
does'nt appear to have worked very well on this one ;)
Did you guys like the report I found it interesting, Didn't find any pics of the fire alarm so not sure where they got the info from, unless that was from who ever checked the fire panel when it was first activated.
You engineer read the report :shy: like in the film short circuit
It said that the roof space sensor was the first activation,
Maybe i am very sad reading it that well,
I am over your way tommorow in bristol,
