Keypad And Accenta G3
Had this system for a while but after christmas sound stopped on keypad,got that back..But now keypad will not accept code or orignal code (0123)...Found battery is pushing just over 8 volts (should be 12) but with this disconnected still will not accept any code...Is their a master over ride?;
Long shot maybe a key is stuck , maybe open it up seems you done everything else and clean it up, is it led version?
House basher's will soon be here with better advice I am sure!
Perhaps wiring incorrect double check what you fixed
Even with main power connected...It has never been on battery power
If the battery was connected to the control panel it would be drawing more current than the system is designed to supply, cooking the charging circuit. The system is designed to be powered from the battery and the PSU is constantly charging the battery.
