Emergency Lights Fixing
alarmcom
Do your customers also know they are going to have unnecessary increased electricity bills and increased lamp failure rates.
Yes the lighting cost was established before I started the work and the annual running cost of LED at well under a £100 PA + The benefit of additional 24 hour lighting both internally and externally was seen as a plus.
Why do you think FP only suitable for Central battery?
You think just like my mate using just the worm is rough and just like my mate haven't said why. I have always fixed trunking this way and to me it's thinking out of the box as I only align and fix once rather than align mark plug realign and screw. Surely if it's securely fixed then how can it be rough? Guarantee I will remove any fitting screwed into a worm drive before mine can be removed.
moaning about which ever choice of fixing to me is a load og bollox
BUT, why you say 'why do you think' FP is only suitable for CB systems' the fact is, the regs used to say that.
We do not dream up why certain cables are used, do you not have a copy of the BS regs.
To say FP can ONLY be used on CB systems is bollox, but it used to be the genberal jist of BS regs.
i have access to regs but I should read them more. I normally use them as a reference when I don't understand. Thanks for thinking out of the box Adi. :)
Sounds harsh, but unless you read and understand them before you go servicing, theres not a lot of point putting the key in the ignition.
It's all unregulated anyway, bs just so insurance pays out and any excuse to not pay
****, you been smoking the hash pipe again.
