Southernnewbie Posted November 15, 2015 Share Posted November 15, 2015 Hi all I have an abacus 6p led display in my unit. It's around 20 years old and never had a problem. Following a massive power cut it is coming up with error zone 6b. The issue is I don't have a 6b. I have a zone 6 (360 dtec) but not a 6b. The system is regularly maintained and has never had an issue. Any ideas what 6b is? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39355-abacus-6p-zone-6b-fault/ Share on other sites More sharing options...
whistle Posted November 15, 2015 Share Posted November 15, 2015 Normally means you have a short on a cable or at the detector unless you are using splitters. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39355-abacus-6p-zone-6b-fault/#findComment-434764 Share on other sites More sharing options...
Southernnewbie Posted November 15, 2015 Author Share Posted November 15, 2015 Nope , no splitters. I will check for shorts. buddy. Apologies for the emoji. It did itself. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39355-abacus-6p-zone-6b-fault/#findComment-434765 Share on other sites More sharing options...
PeterJames Posted November 15, 2015 Share Posted November 15, 2015 If you have access to the engineers area I would check that 6b is not on, abs have a habit of forgetting stuff especially as they get older Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39355-abacus-6p-zone-6b-fault/#findComment-434768 Share on other sites More sharing options...
al-yeti Posted November 15, 2015 Share Posted November 15, 2015 You must have changed a setting , turned on zone splitting in error? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39355-abacus-6p-zone-6b-fault/#findComment-434783 Share on other sites More sharing options...
Southernnewbie Posted November 15, 2015 Author Share Posted November 15, 2015 Definately no splitter. Crashed and reprogrammed panel. I will check for a short. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39355-abacus-6p-zone-6b-fault/#findComment-434792 Share on other sites More sharing options...
al-yeti Posted November 15, 2015 Share Posted November 15, 2015 If you crashed it then you may have to check your programming Maybe you selected zone split by mistake Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39355-abacus-6p-zone-6b-fault/#findComment-434794 Share on other sites More sharing options...
Nova-Security Posted November 16, 2015 Share Posted November 16, 2015 You will need to programme the outputs up first, Abacus have a strange thing when effected by power or crashed that the outputs all become 00 and this shows all sorts of strange faults including 6B split www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39355-abacus-6p-zone-6b-fault/#findComment-434823 Share on other sites More sharing options...
