Optima Xm Problems Please Help !
gazh
Well seems what your doing is ok, and as above when you connect the battery it will siren as cover is open , this was me too ed above, if cable is ok and bellbox is ok and your panel isn't faulty then when you connect the battery the bell will sound until you close the lid and close the tamper
hi yes thanks for the info its much appreciated , im having problems getting pics up , when i replace the cover on bellbox and cover on panel the keypad is locked ...no response when trying to enter the code ?? is there anything i could try or can you advise my next move thanks gaz
Temporary fix move ribbon cable about a bit or push it in should resolve the keypad issue short term
Otherwise change the panel its old hat now
I would concentrate on the panel before bell box though , link tr or t at. Panel to 0v temporarily while you try and fix keypad issue
Better to scrap it though
